phosphor_gradient_14.pyUpdate this file on your badge for the simplest way to change the phosphor persistence to 100%. A side effect is the loss of the menu highlighting feature, so you will have to navigate in the blind. A more complete firmware update is pending with a little more free time...x-python-script - 677.00 bytes - 11/13/2023 at 14:51 |
Potentiometer knob v5.stl3D printable knob. PETG or PLA 0.2mm layers.Standard Tesselated Geometry - 266.10 kB - 11/08/2023 at 05:14 |
Pot P160 datasheet.pdfThis project uses two of the potentiometers. 10K is a reasonable value, others will work. Cut down about 1/3 to 1/2 of the stem so the knobs fit closer to the frame.Adobe Portable Document Format - 600.40 kB - 11/08/2023 at 04:56 |
HackASketchBodyFinal_0.4n_0.2mm_PLA_MK3_2h0m.gcodeSliced version of the body for printing in PLA on a Prusa MK3 with 2 colors and support. Near the end of the print you will get prompted to change the filament for the gold lettering layer.gcode - 2.68 MB - 11/08/2023 at 04:42 |
HackASketchKnob_0.4n_0.2mm_PLA_MK3_13m.gcodeSliced version of the knob for printing in PLA on a Prusa MK3. You will need 2 of these.gcode - 1.49 MB - 11/08/2023 at 04:42 |
HackASketchBodyFinal.stlSTL of the main bodyStandard Tesselated Geometry - 441.20 kB - 11/08/2023 at 04:41 |
HackASketchKnob.stlSTL of the knobStandard Tesselated Geometry - 248.81 kB - 11/08/2023 at 04:41 |
