I'm using standard pitch female headers to make connectors for the tile buttons. I cut a longer header into 4 pin lengths. I found it easier to attach the wires to the header before attaching them to the button.
![](https://cdn.hackaday.io/images/5039811700251310405.jpg)
Above you can see the header connector attached to four wires that are about 65 mm in length. I used some heat shrink tubing to prevent shorting and to further secure the connector. Then solder the wires to the sensor PCB from below as pictured below.
![](https://cdn.hackaday.io/images/8232681700252076756.jpg)
Now assemble the tile holder button as described in the PCB Tile Holder Buttons log.
![](https://cdn.hackaday.io/images/4056631700253499567.jpg)
Then a quick test.
![](https://cdn.hackaday.io/images/3983351700253537699.jpg)
And on to the next. Time for some assembly line work.
![](https://cdn.hackaday.io/images/4164411700323925760.jpg)
Imagine a fast forward video of me assembling these button holder sensor units.
![](https://cdn.hackaday.io/images/733901700333974841.jpg)
Again assemble the remaining five tile holder buttons as described in the PCB Tile Holder Buttons log.
