Scope Comparison Test
12/17/2023 at 01:09 • 0 commentsIn this test I compare a trace taken by the curve tracer to a trace taken using an AD3 scope, a function generator, and a sense resistor. This is done for the 1N4001 and 1N4148 diodes. The results are shown below. They appear to be pretty close.
Comparison Test
12/10/2023 at 00:59 • 0 commentsThis is a test comparing manual measurements of diode curves to curves captured by the curve tracer. The manual measurements were done by current limiting a power supply and reading out the voltage. As can be observed from the plots, I didn't take many data points. The 1N4001 comparison seems pretty close; however, the 1N4148 has noticeable error. This may just be because the 1N4148 is zoomed in more.
Mounted the Circuit Board in an Enclosure
11/29/2023 at 01:32 • 0 commentsThe circuit board is mounted in an enclosure with stand offs. The screw terminal connections are run to banana connectors.
