Overview of Maple ESP32
Maple ESP32 is developed by AnalogLamb. It’s for ESP32 developer. It has a Micro-SD Interface, Compatible with Arduino Interface. It provides a CP2104 USB-TTL serial adapter, programming and reset buttons, and a power regulator to supply the ESP32 with a stable 3.3 V. Espressif doubled-down on the CPU resources for the ESP32 with a dual core, running at 160MHz and tons more pins and peripherals. If you want to buy Maple Series products, Please see here: <a href="http://www.analoglamb.com/product-category/esp32/" target="_blank">http://www.analoglamb.com/product-category/esp32/</a>
Features
ESP32 Supports WiFi and BT
1 x Micro-SD Card Interface
1 x CP2104 – USB to UART Bridge
1 x Battery Interface
LDO output current about 800mA
Supports Auto download circuit
2 x Buttons for Reset and Boot
Program with Arduino IDE
Files
Schematic__Maple ESP32 R1.pdf
Adobe Portable Document Format -
456.13 kB -
01/10/2017 at 09:20
Hi, It's a real project, so we want to share with people. And we also hope some persons can use it to develop. The idea is come from leaflabs maple board. The dimension & interface are same completely. But It's a ESP32 board.
The Flash size is 4MB. Because of no ESP32 chip, we are using ESP-WROOM32 of ESpressif.
1. Is this just an ad?
2. The name is likely to conflict with this established product: https://www.leaflabs.com/maple/
3. You don't seem to say how much Flash it has.
