Arduino Time Sync from NTP Server using ESP8266
Using ESP8266 as a Real Time Source with NTP Servers and Arduino
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
In this project we are going to use an ESP8266 module to connect to the internet and get the real time from a pool NTP Server and then deliver the time to an Arduino UNO R3 via Serial protocol. So practically the ESP module will work as an RTC for the UNO. For complete thorough tutorial follow links bellow: <a href="http://www.geekstips.com/arduino-time-sync-ntp-server-esp8266-udp/" target="_blank" class="icon-other">Arduino NTP Server Tutorial</a> <a href="http://www.geekstips.com/esp8266-arduino-tutorial-iot-code-example/" target="_blank" class="icon-other">ESP8266 Arduino Module Tutorial</a>
