The project continues
A project log for Answer or Die
The final challenge before you can escape of the room
aliaAĆ©lia 01/12/2024 at 10:100 Comments
07/12/2023 - 14/12/2023
The screen touch is hard to make it work
But we did it !
The screen touch AND the ring light go on when the digital touch is touch
https://streamable.com/isy10m
But we need the screen touch to show questions and answer, so let's try to make it post something
https://streamable.com/h58ehe
We also made a code for the ring light, to turn it into a timer for each questions. It start with all the led and every seconds (not sur of the timing) one led go off, and when there is no more light, the timer is finished.
