Mount.stlThe is the mount of the wheel which will be used to connect the motor to any surface using screws.Standard Tesselated Geometry - 150.38 kB - 11/27/2023 at 16:43 |
Body.stlThis the main hub of the wheel in which motor sits.Standard Tesselated Geometry - 113.75 kB - 11/27/2023 at 16:43 |
