PFBDK_promicro.kicad_sch_v1.1.pdf
An updated schema. The on-board RS-232c interface was never tested, but the ground is incorrectly connected to pin 1. The 1.0 version of the board has this fault. The correct pin is 5.
Adobe Portable Document Format - 63.18 kB - 12/20/2023 at 17:49
Preview
PFBDK_promicro.kicad_sch.pdf
This is a first production version. A PCB is created for this schema. This applies to the version 1.0 of the board. Note it has a problem with the RS232c ground pin, easy to correct during assembly.
Adobe Portable Document Format - 62.53 kB - 12/08/2023 at 20:54
Preview
PxDiskMega.kicad_sch.pdf
This is the prototype / development version. There is no PCB.
Adobe Portable Document Format - 61.96 kB - 12/08/2023 at 20:51
Preview
