A Smarter On-Air Light
Avoid those pesky interruptions during your video meetings without lifting a finger!
Want to avoid that situation where a random family member or coworker walks into the background of your Zoom meeting because they didn't know you were live? Have you tried to program microcontrollers past blinking an LED and gave up from frustration? Do you wish to wield the power of webhooks in your hardware project? Join me on a journey to create an automated on-air light that updates based on my Zoom meeting status, powered by an ESP32 and Viam .
I would hate to be this guy at work during an important interview or meeting.
My son is starting become more mobile and explore all the different spaces around my house. I've always wanted some sort of indicator to him, my wife, and anyone else in the house that I'm currently in a meeting without needing to remember turn it on or off. It would also be useful if it could help me remember when the meeting has started; I think we've all been there when a reminder for a meeting comes up 5 minutes before it starts and then it completely slips your mind until 5 minutes after it starts.  😅
To accomplish this task, I used a cardboard box, an ESP32, an RGB LED, and a USB battery (along with the wires and cables to connect them all together). The ESP32 is a very popular microcontroller because it provides Wi-Fi, Bluetooth, plenty of GPIO, and a solid amount of memory and storage for its form factor while staying relatively low-power, so it can run all day using the USB battery. Since I didn't need to worry about connecting to an outlet, the light can be mounted wherever I like.
This also gave me a chance to try the latest release of the Viam micro-RDK, so I could securely connect to and program the device with my choice of languages. Typically, when a network-connected device in a home (or office) needs to communicate with the world wide web, there are a few methods to do it:
- Some code on the device could check in with a cloud service to see if there is any relevant information with which it can take action; this is called "polling", which is a quick and valid approach when you're not worried about power or checking the service too often for updates.
- The device could also "subscribe" to updates from a messaging service in the cloud using MQTT or another "pub/sub" protocol. This is more efficient for the device and can be useful for scaling those updates to many devices, which is not a concern for my project; plus it adds a layer of complexity to the stack to maintain this project over time.
- There is also "hard mode": opening a public port on the network router and forwarding a request to the public IP address to the device, which could have security implications if done incorrectly and it's not guaranteed that the IP address will always stay the same since typical home service providers can reassign them at will.
Devices connected to Viam take a different approach entirely. The RDK and micro-RDK use gRPC to establish a secure peer-to-peer WebRTC connection with the Viam cloud service and any programs using one of Viam's SDKs. This means any communication goes directly to/from the device without worrying about exposing private networks to the public internet or managing additional cloud services in-between.
To control the light automatically based on my Zoom status, I created a webhooks-only app written in Python connected to my account. I deployed it to Fly since they make it so easy to launch web applications for free.
Check out the working demo video below and read the build instructions to learn how to set up a smarter on-air light for yourself!
  • 1 × ESP32 development board Should be one of the WROOM or WROVER series with at least 2 Cores + 384kB SRAM + 4MB Flash
  • 1 × Diffused RGB LED Get as many as you'd like in your project - https://www.adafruit.com/product/159
  • 4 × Male-to-Male jumper wires Other jumper wire types are fine if you're using a breadboard for the components
  • 1 × USB data cable It will be used to connect the development board and your computer, as well as power from the USB battery later
  • 1 × USB battery Any size that fits in your container for all the components
View all 6 components
  • 1
    Wiring the components
    We'll start off by wiring the RGB LED to the ESP32:
    The diagram above shows a breadboard for clarity, but the RGB LED and ESP32 could be wired directly together using male-to-male jumpers if you choose.
    Take note of the GPIO pin numbers connected by red, blue, and green jumper wires to three of the LED legs, any GPIO that support digital output or pulse width modulation (PWM) will work; check your board's pinout to verify. Here we're using GPIO pins 15, 32, and 14. Those values will be important for configuring the development board in the Viam app and the Python code later. The jumper connecting the 3V pin on the ESP32 board to the LED will provide power to the component when the board is connected to your computer or the battery over USB.
  • 2
    Flash and configure the ESP32 in Viam
    Next is creating a new robot in the Viam app and following the "Setup" instructions to flash the ESP32 with the micro-RDK.Once you've confirmed that it is connected to Viam (you should see a "Live" status under "Last online" in the header of the app), configure the board component  and relevant pins using the following JSON:
      "components": [
          "attributes": {
            "pins": [
              15,
              32,
              14
          "depends_on": [],
          "name": "board",
          "model": "esp32",
          "type": "board",
          "namespace": "rdk"
     Remember to replace the numbers in the list of `pins` with the ones matching the physical wiring of the project.
    Restart the ESP32 to confirm a working configuration. If there is a "reset" button on the development board, use that; otherwise, unplugging and plugging in the board also works. You can look at the Control tab in the app to read and write the configured pin values to control the LED. Try setting all the pins to 1 or 0 or a floating number in between like 0.5 to see what happens.
  • 3
    Web Application Setup
    Now to build the web application that will accept webhook requests from Zoom and control the light, we'll use the Viam Python SDK with the Starlette async web framework. Clone the working project from GitHub.
    git clone https://github.com/HipsterBrown/viam-on-air.git
    To configure the application with the required API key, API key ID, and location address for the Viam SDK and the secret token from Zoom, make a copy of the `.env.example` file and call it `.env`.
    Get the Viam API and location values from the "Code Sample" tab when viewing the machine details in the app. Toggle the "Include API Key" switch to reveal the API Key and API Key ID in the code where "<API-KEY>" and "<API-KEY-ID>" is seen initially.
    Get the Zoom secret token by creating a webhook-only app in the Zoom App Marketplace  and subscribing to the following events when adding an event subscription:
    Update the `.env` file with the relevant values, including the configured pins from Viam as `RGB_PINS` and your Zoom username to make sure the light only updates when you join or leave a meeting.
    With a working Python development environment, run the install command to get the dependencies in the cloned project repository:
    pip install -e .
    Start the web application:
    python -m viam_on_air
    This will connect to the ESP32 and start a webserver on `0.0.0.0:8000` (a.k.a `localhost:8000`).
    ❯ python -m viam_on_air
    INFO: 	Started server process [96243]
    INFO: 	Waiting for application startup.
    2023-11-22 17:40:02,956     	INFO	viam.rpc.dial (dial.py:286) 	Connecting to socket: /tmp/proxy-LSL4xP2F.sock
    INFO: 	Application startup complete.
    INFO: 	Uvicorn running on http://0.0.0.0:8000 (Press CTRL+C to quit)
View all 6 instructions
