Once all the parts were turned; assembly was mostly a matter of just fitting everything. I had however made the pins too long; so that needed a bit shortening. And the magnets had to be glued in.
A project log for Low profile PCBite PCB holders
Sensepeek.com their PCBite holders are wonderful -- but a bit high for your average SMD microscope. Let's make some low-profile ones !
