Low profile PCBite PCB holders
Sensepeek.com their PCBite holders are wonderful -- but a bit high for your average SMD microscope. Let's make some low-profile ones !
Public Chat
Sensepeek makes lovely PCBite PCB holders; that work well and last forever. But as every review will tell you - they do not work well with your average SMD two-eye microscope. As they are too high.
I.e. they put the PCB too far up - making either focusing hard - or requiring you to sit on a very big stack of pillows.
Unfortunately - Sensepeek only makes one size. So let's fix that.
Elements:
  1. Magnet; 20x3mm (the 1 and 1.5mm disk magnets are a bit too weak, though quite usable with a base made of a heavier metal (e.g. brass or steel rather than Aluminum)
  2. Base; outer diameter not critical; e.g. 22mm; inner diameter should match the sliding part; e.g. 18mm. Inset at button for magnet; 0.5mm less than the magnet height. Cup depth should be more than 10mm. Threaded hole at the bottom.
  3. Sliding part; outer diameter should fit base cup; e.g. 18mm. Inside bore should fit spring (e.g. 11mm) and the hole should fit the pin
  4. Pin; Threaded at the bottom. Should fit the hole of the sliding part and the spring should fit around it.
Easiest is to make the sliding cup first; and match the hole in the base to it.
  • Day 2
    Dirk-WIllem van Gulik12/28/2023 at 21:20 0 comments
    Once all the parts were turned; assembly was mostly a matter of just fitting everything. I had however made the pins too long; so that needed a bit shortening. And the magnets had to be glued in.
  • Day one
    Dirk-WIllem van Gulik12/28/2023 at 21:18 0 comments
    Now at the Makerspace leiden we have a nice lathe. And there is usually plenty of scrap laying around. This time someone has donated some very tick aluminium pegs; one of these is just about the right amount of material.
    First step is to determine the order. We want things to fit reasonably well so that nothing is wobbly (though the spring will help compensate just about anything).
    We need to make three things; a the bottom 'cup' with a recess at the bottom for the magnet. The sliding middle thing ; which essentially is also a 'cup' for the spring. And the pin that goes through the middle with a flat top.
    For the middle bit - it is somewhat critical to have the outer walls parallel to the inner wall that slides along the middle pin to prevent binding. The same applies to the inner walls of the bottom cup and the threaded hole in the bottom.
    So we'll do those in one session; without taking it out of the three-claw chuck.
  • Getting started
    Dirk-WIllem van Gulik12/28/2023 at 21:13 0 comments
    Now given that Sensepeeks sells spare isolation rings and sliding covers for a reasonable price (a roll of low friction teflon, ptfe or hmwd tape is not exactly cheap) -- we'll try to keep the design such that these are still usable should we want to.
    And secondly - as we have some disk magnets  laying around - we'll want those to fit.
    So that yield a quick design:
    We have three parts; a Botton holder with an M8 thread and a bit of a hollow space for the magnet.
    A sliding thingy in the middle with a ID=8.5 OD=10, L=25 spring under it; and then a mushroom shaped thing at the top that is fixed into the Bottom holder. The spring size is not critical; these springs happend to be in the bits&bobs bin at the MSL.
    Contrary to the PCBIte originals - we make the sliding thingy a little wider than the top mushroom bit. This is that, unlike the original where you have a fair bit of grab-space thanks to the hight, so you have something to help you push down on.
    And as we really like knurling - we'll need to find a reason to that.
View all 3 project logs
Tito wrote 01/03/2024 at 17:57 point
I bought pcbites clones from aliexpress, and cut the springs in half, and bought smaller screws. My pcb's are now 21mm from the table.
