New boards
07/13/2017 at 19:56 • 0 commentsNew boards ready. It can read data from GROVE interface and control the pump by relay.
Can be bought from tindie
Source code
06/21/2017 at 20:02 • 0 commentsSource code is on the github
Boards for sale
06/21/2017 at 19:47 • 0 commentsBoard for measuring moisture with FDS-100 (4-20 mA version) or with any I2C sensor can be purchased at tindie
Control the pump
06/17/2017 at 10:11 • 0 commentsDesigning the second part of the system: pump controller. The device will receive the data from the Thingspeak and control the water pump.
Webserver for parameters
03/12/2017 at 20:26 • 0 commentsAdded webserver for setting parameters for the Thingspeak.
And most important feature is remote firmware update, by the webpage.
Useful library is ESP8266HTTPUpdateServer.h
Current status
01/21/2017 at 18:28 • 0 commentsThe board is up and running. Sensor output measures by analog input of ESP8266.
Useful library: thingspeak-arduino
Victor
