PC-XINU.imgA Pre-built copy for people who don't have time to create their own...img - 1.41 MB - 01/05/2024 at 04:46 |
startupPut this in the XINU directory of the boot disk template. You can customise the colours in a text editor.startup - 121.00 bytes - 01/05/2024 at 04:45 |
BOOT DISK TEMPLATE.imgA stripped-down version of the MSDOS 6.22 Boot Disk used for creating the PC-XINU floppy.img - 1.41 MB - 01/05/2024 at 01:45 |
slip8250.zipUnzip this. You will find an executable inside. Put this in the XINU directory of the boot disk template.x-zip-compressed - 3.71 kB - 01/05/2024 at 01:43 |
dpmiload.zipUnzip this. You will find an executable inside. Put this in the XINU directory of the boot disk template.It loads the XINU OS in protected mode. x-zip-compressed - 10.77 kB - 01/05/2024 at 01:43 |
dpmi16bi.ovlPut this in the XINU directory of the boot disk template. It runs XINU in protected mode.ovl - 59.25 kB - 01/05/2024 at 01:41 |
xinu79.zipUnzip this. You will find an executable inside. Put this in the XINU directory of the boot disk template. It is the main file.x-zip-compressed - 109.46 kB - 01/05/2024 at 01:40 |
AUTOEXEC.BATReplace the autoexec.bat in the boot disk template (included) with this...bat - 300.00 bytes - 01/05/2024 at 01:36 |
xinu.batPut this in the XINU directory of the boot disk template.bat - 193.00 bytes - 01/05/2024 at 01:35 |
l3x12.zipSource code from the website if you want to edit it...x-zip-compressed - 1.75 MB - 01/05/2024 at 01:34 |
