1Step 1
Introduction
This guide details the steps for installing WiiStream on your Nintendo Wii. Follow each step closely for a successful setup.
Prerequisites
- A Nintendo Wii matching one of the model numbers here
- An SD card
- A PC with internet access (here I'll be using Windows but macOS and Linux will work too)
- A USB keyboard
Installation Steps
1. Homebrew Your Wii
- Follow the steps outlined in these guides to homebrew your Wii:
- Letterbomb Guide
- Homebrew Channel Installation (Install BootMii as boot2. Note: If 'install as boot2' is not available, your Wii is incompatible)
- BootMii Guide
2. Prepare the SD Card
- Download Wii-Linux-ngx from this link and extract the file.
- Insert the SD card into your PC.
On Windows:
- Open Rufus available here.
- Select your SD card under 'Device'.
- Under 'Boot selection', click 'SELECT' and choose the extracted "wii-jessie-sd.img" file.
- Click 'START' and accept the warning prompt.
- Click 'CLOSE' when it shows 'READY'.
- Open Paragon Partition Manager.
- Select the partition named "WII-LINUX-NGX" (usually the middle partition).
- Click 'Expand', follow the prompts, select 'Expand Now', and wait for completion.
- Ignore the prompt about 'reinit your bootloader'.
- Remove the SD card from your PC.
3. Wii Setup
- Connect a USB keyboard to the back of the Wii, using the USB port at the bottom when the Wii is horizontal.
- Insert the SD card into the Wii and turn it on.
- Wait for the Gumboot menu to boot into the first option (wii-linux-ngx) after 30 seconds.
- Wait for wii-linux-ngx to boot up.
- Log in with 'root' as both the username and password.
4. Configure Network on Wii
- At the prompt, enter
./whiite-ez-wifi-config
and follow the instructions for WiFi setup.- Ensure you use 'WPA-PSK' as your WLAN Security Mode.
- Select 'Yes' when prompted to bring up your WiFi connection.
- Select 'No' after it fails to bring the connection up.
- Edit network interfaces with
nano /etc/network/interfaces
.- Change all instances of 'wlan0' to 'wlan1'.
- Save and exit (Ctrl-X, Y, Enter).
- Activate the new interface by typing
ifup wlan1
. - Type in
nano /etc/apt/sources.list
and change the first line to 'archive.debian.org...' instead of 'httpredir.debian.org...'
5. Remote Access Setup
- Modify SSH settings with
nano /etc/ssh/sshd_config
.- In the file, change 'PermitRootLogin without-password' to 'PermitRootLogin yes'.
- Reboot the Wii by typing
reboot
, then log back in. - Type
ifconfig
to find the Wii's IP address (noted under 'wlan1 inet addr').
6. Access Wii from Another Computer
- On another computer, access the Wii via a terminal:
- Type in
ssh root@<Wii's IP address>
. - The password is 'root' (input is invisible).
- Type in
7. Create Swap File
- Execute the following commands to create a swap file. The first command may take a while:
dd if=/dev/zero of=/swapfile bs=1M count=5120 chmod 600 /swapfile mkswap /swapfile swapon /swapfile nano /etc/fstab
- Add
/swapfile none swap sw 0 0
to the end of the file and save.
- Add
8. Install Mopidy and Dependencies
- Run
apt update
. - Install required packages:
apt-get install python curl python-dev python-pip gstreamer0.10-alsa gstreamer0.10-pulseaudio python-gst0.10 gstreamer0.10-plugins-good gstreamer0.10-plugins-ugly gstreamer0.10-tools pulseaudio python-pykka python-gi
- Install Mopidy and related components:
curl https://bootstrap.pypa.io/pip/2.7/get-pip.py -o get-pip.py python get-pip.py pip install Mopidy==0.19.0 pip install Mopidy-MusicBox-Webclient==2.0.0 Mopidy-TuneIn==0.1.3 Mopidy-Podcast-iTunes==1.0.0 --no-deps
9. Configure Mopidy
- Create and configure the Mopidy service file with
nano /etc/init.d/c_mopidy
.- Paste the provided script, save and exit.
#!/bin/sh ### BEGIN INIT INFO # Provides: mopidy # Required-Start: $network $remote_fs # Required-Stop: $network $remote_fs # Should-Start: $named alsa-utils avahi dbus # Should-Stop: $named alsa-utils avahi dbus # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: Mopidy music server ### END INIT INFO PATH=/sbin:/usr/sbin:/bin:/usr/bin:/usr/local/bin:/var/log DESC="Mopidy music server" NAME=mopidy DAEMON=/usr/local/bin/mopidy DAEMON_USER=mopidy DAEMON_GROUP=audio CONFIG_FILES="/usr/share/mopidy/conf.d:/etc/mopidy/mopidy.conf" PIDFILE=/var/run/$NAME.pid SCRIPTNAME=/etc/init.d/$NAME # Load the VERBOSE setting and other rcS variables . /lib/init/vars.sh # Define LSB log_* functions. . /lib/lsb/init-functions start_pulseaudio() { # Start pulseaudio in system-wide mode /usr/bin/pulseaudio --system --daemonize >> /var$ sleep 5 # Give pulseaudio 5 seconds to initialize } do_start() { start_pulseaudio # Ensure pulseaudio is running before starting mopidy start-stop-daemon --start --quiet --name $NAME --pidfile $PIDFILE \ --startas $DAEMON --test > /dev/null \ || return 1 start-stop-daemon --start --quiet --name $NAME --pidfile $PIDFILE \ --chuid $DAEMON_USER:$DAEMON_GROUP --background --make-pidfile \ --startas $DAEMON -- --quiet --config $CONFIG_FILES \ >> /var/log/mopidy.log 2>&1 \ || return 2 sleep 5 } do_stop() { start-stop-daemon --stop --quiet --name $NAME --pidfile $PIDFILE \ --retry=TERM/30/KILL/5 RETVAL="$?" [ "$RETVAL" = 2 ] && return 2 # Wait for children to finish too if this is a daemon that forks # and if the daemon is only ever run from this initscript. # This typically happens with pulseaudio. start-stop-daemon --stop --quiet --oknodo --user $DAEMON_USER \ --retry=TERM/30/KILL/5 [ "$?" = 2 ] && return 2 rm -f $PIDFILE return "$RETVAL" } # Remove the action from $@ before it is used by the run action action=$1 [ "$action" != "" ] && shift case "$action" in start) [ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC " "$NAME" do_start case "$?" in 0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;; 2) [ "$VERBOSE" != no ] && log_end_msg 1 ;; esac ;; stop) [ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME" do_stop case "$?" in 0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;; 2) [ "$VERBOSE" != no ] && log_end_msg 1 ;; esac ;; status) status_of_proc "$DAEMON" "$NAME" && exit 0 || exit $? ;; restart|force-reload) log_daemon_msg "Restarting $DESC" "$NAME" do_stop case "$?" in 0|1) do_start case "$?" in 0) log_end_msg 0 ;; 1) log_end_msg 1 ;; # Old process is still running *) log_end_msg 1 ;; # Failed to start esac ;; *) # Failed to stop log_end_msg 1 ;; esac ;; run) echo -n "\"service mopidy run\" is deprecated. " 1>&2 echo "Use \"mopidyctl\" instead." 1>&2 /usr/sbin/mopidyctl $@ ;; *) echo "Usage: $SCRIPTNAME {start|stop|status|restart|force-reload|run}" >&2 exit 3 ;; esac :
- Make it executable with
chmod +x /etc/init.d/c_mopidy
and enable defaults withupdate-rc.d c_mopidy defaults
- Create the 'mopidy' user and configure permissions:
- Use any password. Leave the remaining fields blank during this step.
adduser mopidy
usermod -a -G audio mopidy usermod -a -G audio pulse
- Configure PulseAudio:
- Edit
nano /etc/pulse/system.pa
. - Add
load-module module-native-protocol-tcp auth-ip-acl=127.0.0.1 auth-anonymous=1
at the end.
- Edit
10. Final Steps
- Create Mopidy configuration directory and file:
mkdir /etc/mopidy nano /etc/mopidy/mopidy.conf
- Paste the provided configuration, save and exit:
[local] enabled = true data_dir = /var/lib/mopidy/local media_dir = /var/lib/mopidy/media playlists_dir = /var/lib/mopidy/playlists [audio] output = pulsesink server=127.0.0.1 [stream] enabled = true protocols = http https mms rtmp rtmps rtsp timeout = 5000 metadata_blacklist = [mpd] enabled = true hostname = 0.0.0.0 port = 6600 [http] enabled = true hostname = 0.0.0.0 port = 6680 [tunein] timeout = 5000 [podcast-itunes] enabled = true # iTunes Store base URL base_url = http://itunes.apple.com/ # user-friendly name for browsing the iTunes Store root_name = iTunes Store # format string for genre results; field names: id, name, url genre_format = {name} # format string for podcast results; field names: collectionId, # collectionName, country, kind, trackCount podcast_format = {collectionName} # format string for episode results; field names: collectionId, # collectionName, country, episodeContentType, episodeFileExtension, # episodeGuid, kind, releaseDate, trackId, trackName episode_format = {trackName} [{collectionName}] # charts to display when browsing; possible values: "Podcasts", # "AudioPodcasts", "VideoPodcasts" charts = AudioPodcasts # directory name to display for browsing charts of a genre/category # with subgenres; field names as for 'genre_format' charts_format = All {name} # ISO country code for the iTunes Store you want to use country = US # whether you want to include explicit content in your search # results; possible values: "Yes", "No", or store default (blank) explicit = # HTTP request timeout in seconds timeout = 10
- Allow the Reset button on the Wii to shut it down.
- In
nano /etc/inittab
:- Change the line starting with 'ca:12345:ctrlaltdel' from:
ca:12345:ctrlaltdel:/sbin/shutdown -t1 -a -r now
to
ca:12345:ctrlaltdel:/sbin/shutdown -t1 -a -h now
- Reboot the Wii to apply changes by typing
reboot
Starting Mopidy
Power on the Wii to start the Mopidy music server. Connect to Mopidy in a browser on another device via the Wii's IP address over port 6680, e.g. http://192.168.30.10:6680
