Raspberry Pi HPC for molecular dynamic & AI models in high school classrooms
We set off building a compute cluster using the Raspberry Pi Compute Module 4 for its smaller form factor and higher customizability.
5 Jan 2024 - 7 Jan 2024
When connecting a WaveShare board with the CM4 don't fret to press hard to make sure it connects properly with an audible click.
manually configure network
the file
sudo nano /etc/network/interfaces.d/eth0
the content
auto eth0 iface eth0 inet dhcp ``` Replace the `dhcp` option with `static`, and add the IP address, netmask, gateway, and DNS server information. For example: #auto eth0 #iface eth0 inet static # address 192.168.1.100 # netmask 255.255.255.0 # gateway 192.168.1.1 # dns-nameservers 180.76.76.76
list of DNS servers used Baidu's
sudo nano /etc/resolv.conf
nameserver 180.76.76.76
netowrk error even after correct setup -> incompatible router problem
The CM4 didn't work on the Huawei router that came with 中国电信 (ISP) but worked on the newifi router.
After switching the connected router, we were able to successfully ping baidu.com with 45~ ms.
OpenMPI is not OpenMP. OpenMP is for a single device with shared memory while OpenMPI is for multiple devices.
View project log
Gregor von Laszewski
Chris
Dimitris Matsoukas
Dmitry
Yes, delete it Cancel
You are about to report the project "Raspberry Pi Computing Cluster", please tell us the reason.
