DIY Smart 3D Printer Enclosure
Welcome to the DIY Smart 3D Printer Enclosure project! This setup is designed to elevate the safety and performance of your 3D printing experience. Featuring sensors for real-time monitoring of temperature, humidity, and light levels, this enclosure incorporates a versatile exhaust fan and customizable lighting, all effortlessly controlled through the Blynk mobile app.
What makes this project stand out? Well, it's a solution tailored for both FDM and, especially, resin-based 3D printers, addressing potential fume issues that can impact our health. Utilizing the power of ESP32 coupled with environmental sensors, we're equipped to ensure a healthier and smarter 3D printing space by effectively managing fumes and environmental conditions. Let's make our 3D printing space both smarter and healthier!
Sponsored By NextPCB
This project is successfully completed because of the help and support from NextPCB -Reliable Multilayer PCB Manufacturer. NextPCB is one of the most experienced PCB manufacturers in Global, has specialized in the PCB and assembly industry for over 15 years.
Order you high-quality PCB starting at $1.9, multilayer starting at $6.9.
Enjoy Free PCB assembly for 5 boards.
Try DFM free online PCB Gerber viewer.
View all 11 components
  • 1
    Supplies
    1x Duct Fan
    1x Dryer Vent Hose
    1x Draft Blocker Backdraft
    1x FireBeetle 2 ESP32-E
    1x Gravity Environmental Sensor
    1x Relay Module
    1x IRF520 Mosfet
    1x L7805CV Voltage Regulator
    1x Super Bright LED Light
    1x Mylar enclosure
    1x DC Jack
    My Tools:
    Sponsored By Hon&Guan:
    This project is made possible by the generous support of Hon&Guan – a leading name in the research and development manufacturing of air replacement, fresh air ventilation, and ventilation equipment. Hon&Guan is a cutting-edge, high-tech enterprise specializing in products like mixed flow inline duct fans, ventilation fans, and AC/DC fans.
    Explore their range of quality ventilation solutions at https://store.honguan.com. Thank you, Hon&Guan, for being a key contributor to the success of this project!
  • 2
    Circuit Connection
    Just refer to the circuit diagram and connect the electronics on the prototyping board. I've used header pins and corresponding electronic components for easy connections and component replacement.
  • 3
    About L7805CV
    The L7805CV is a voltage regulator integrated circuit (IC) that is commonly used to provide a stable and fixed output voltage of +5 volts. This component is part of the 78xx series of voltage regulators, where "78" denotes a positive voltage regulator and "05" indicates the fixed output voltage of +5 volts.
    Here are some key points about the L7805CV:
    1. Voltage Regulation: The primary function of the L7805CV is to regulate the input voltage and maintain a constant output voltage of +5V.
    2. Input Voltage Range: The typical input voltage range for the L7805CV is around 7V to 35V. It can handle higher input voltages, but the excess voltage is "dropped" or dissipated as heat.
    3. Output Current: The maximum output current is around 1.5 amps. It can supply a stable +5V output for electronic circuits within this current limit.
    4. Three-Terminal Device: The L7805CV has three terminals: Input (Vin), Ground (GND), and Output (Vout). Proper connection and orientation of these terminals are crucial for correct operation.
    5. Heat Dissipation: The L7805CV may generate some heat, especially when the input voltage is significantly higher than the output voltage. To prevent overheating, it's common to use a heatsink or ensure adequate ventilation.
View all 11 instructions
