1SOURCE CODE
First we need to download the source code from HERE
You can find assembly language files along with hex and lst files.
If you want to modify anyting then you need to use the assembler .
3WCHISPTool
To program the hex file into the FLASH of the target microcontroller, we need the WCHISPTool which is available from the WCH website.
We can easily program using USB port which supplies VCC, GND and D+ and D-
4Tera Term
Tera Term For serial terminal application download the Tera Term from HERE
5USB-TTL driver
If we are using the onboard USB-TTL feature, we need the driver to recognize by windows. The driver is very generic and can be found HERE
6Components
![CH552T CH552T]()
BOM The user can configure the board by populating the required components.
Machined pins for header Using machined header is useful for both inserting into a breadboard or into a machined IC socket.
mit41301
