SP180_U17-eqn-edited.txt
Edited but unverified
plain - 1.17 kB - 01/31/2024 at 01:43
Download
SP180_U2-eqn-edited.txt
plain - 1.83 kB - 01/31/2024 at 01:43
Download
SP180_U17-eqn.txt
disassembled by JED2EQN.EXE
plain - 1.01 kB - 01/30/2024 at 23:46
Download
SP180_U2-eqn.txt
plain - 1.08 kB - 01/30/2024 at 23:46
Download
SP180_U2.jed.txt
Primary GAL, a 22V10, interfaces the STEbus. An STEbus access asserts the CPU !BUSRQ signal, and accesses the CPU memory space when !BUSGT is asserted.
plain - 7.14 kB - 01/28/2024 at 14:50
Download
SP180_U17.jed.txt
Secondary GAL, a 16V8.
plain - 2.89 kB - 01/28/2024 at 14:50
Download
SP180_rom.bin
Firmware ROM
octet-stream - 16.00 kB - 01/28/2024 at 14:44
Download
plain - 1.06 kB - 02/01/2024 at 23:24
Download
text/plain - 51.87 kB - 01/28/2024 at 14:44
Download
SP180_rom_dump.txt
Hex dump used for spotting ASCII text
plain - 67.15 kB - 01/28/2024 at 14:44
Download
SP180_rom_dis.txt
Best guess so far.
text/plain - 119.55 kB - 01/28/2024 at 14:44
Download
SP180_rom_dis.sh
Script for disassembling the ROM image from Linux command line
application/x-shellscript - 181.00 bytes - 01/28/2024 at 14:44
Download
SP180_rom_symbols_in.txt
I assume the ROM appears at 0000 and 8000 hex, boots from 0000 then jumps to its alias where it then disables the ROM below 8000 hex.
text/plain - 3.36 kB - 01/28/2024 at 14:44
Download
