A rover specifically designed to be deployed to the moon. It is starting off as a low cost technology test bed for higher education. The main body is two pieces of 3D printed parts and the wheels are specifically designed for larger rocks and the lunar regolith.
Will have a 5-megapixel camera, Raspberry Pi Pico, batteries, solar charging circuit, communication system, and various sensors like a radiation and light sensor in a compact chassis that measures 180mm x 104mm.
