GSM device remote control
"Phone" like device to control GSM enabled appliances, like driveway gates, garage doors, building alarm systems
Public Chat
SIM800 based "small" remote, which can dial phone numbers or send SMS to preconfigured numbers. Controlled by Arduino pro mini, with OLED display, 2500mAh Lipol battery, TP4056 USB-C charger, speaker and microphone. Body is resin printed
I did this project because I was annoyed with having to use my phone while driving to open the gate, which is GSM controlled by calling its number, and takes a while to open, so you really want to call in advance. This way I can just push two buttons.
It can also be used as a normal "phone"; it can make calls to any number, it has speaker and microphone, although both suck. I guess it's better than a smartphone with dead battery.
Theoretically, it can last 104 days in stand-by, with sleep consumption of ±1mA. But there are some problems with putting the display to sleep, so it sometimes draws a lot of current even when "off", so it's more like 3 days lol
Putting all the components in a small package sucks, with all the wires it's really hard to make it fit. It's held by tape now; it was designed to be glued, but I didn't want to do that yet. A better version should be on a custom PCB, just for the connections, I would keep the off-the-shelf boards. Maybe with a mosfet for the display.
ino - 6.53 kB - 03/02/2024 at 16:17
Download
Remote phone v11.f3d
Fusion 360 project file
fusion - 1.70 MB - 03/02/2024 at 16:16
Download
  • 1 × SIM800L GSM module, the cheapest one is also the smallest
  • 1 × Arduino pro mini, ATmega328P
  • 1 × TP4056 USB-C charger Modified with 3K3 R3 resistor to limit charge current
  • 1 × 0.91" 128x32 OLED display, I2C
  • 1 × Speaker 1W 8 Ohm - 14 x 20 mm
View all 7 components
  • 1
    Step 1
    1. don't do this
View all instructions
