It took me a couple of tries to get a good clip design, this was freehanded curves
Then the clip I had to get right, the connector was in the way so I went with a split design
I'm printing the body above, it's just over 2 hours
I'll then assemble this and start programming the AP interface, the display will not be functional yet till I figure out how to program it/use it with the RPi via maybe i2c, if nothing else as buttons
Measure thrice... print thrice?...
I really am doing a poor job on this project, I have to get it done and I have other things I'm thinking about (life problems).
But tomorrow will happen, I will be there at that field.
Basic power system wired
![](https://cdn.hackaday.io/images/7496001710816101299.png)
It'll look like this plus the bottom clip attached
I have to reprint it again because I forgot to paste back in the T shape thing that supports the back of the pi... and the pi mounts in the front are too weak/they keep snapping in the process of removing the supporting material... 2.5 hr print gotta do it again...
