1Construct the ball
Our ball is inspired by Jon Paul's balls. You can find the one we took the measurements of at the following link: JPB AL RIHLA BALL .
1. Prepare your patreons and do a prototype in paper to see if the size of the ball is right for you. Ours
2. Cut pieces in the cardboard
3. Cover each pieces with the fabric
4. Assemble them so that you can have your final ball
5. Cut a hole in one of the triangles according to the size of your screen so it can fit perfectly
6. Make the ball more beautiful by cleaning the edges and the inside when we open it
2Coding each component
3Assembling everything
4Instructions Book
- Cover of the book
- Hall Effect Sensor Circuit
- Charging Cable Support
- Assemble everything
- And voilà!
