1The base
Turn the base upside down
Remove the rubber feet to expose the screws
Unscrew four corners
2Step 2
Turn the unit right side up
Pull the blue case up and off
3Step 3
Pull the yellow face plate up and off
Lay it face down next to the base to access the inside of the connector
4Step 4
Note the wire colors before de-soldering
White pair on the left
Black pair on the right
Green on the bottom
Bridge the Bottom and Top (Shield?) with a 1M resistor
5Step 5
To remove the connector:
Plug in the soldering iron cable
Use pliers to squeeze the tabs
Wiggle from the tab side and pull gently from the cable side
6Step 6
Push in the new connector
7Step 7
Unscrew the PCB
Screw on the connector's locking nut
Replace the PCB
8Step 8
Heat-shrink over the 1M resistor (910k...close enough)
9Step 9
Re-solder the connections onto their corresponding pins
(This is when I realized... the shield of this connector does not have a dedicated pin. So in this configuration the resistor is rendered useless. One day I'll move the resistor from the center pin to the connector casing directly.....maybe)
10On to the cable...
Use a small flat screwdriver to pry up the black tab
Pull the black sleeve towards the cable to reveal the innards
