Single-axis joysticks have historically been cumbersome for hobbyists due to their large size and high cost, and while dual-axis joysticks are ubiquitous and commonly available, sometimes a user just wants to control a single axis. In this article, I share a demo unit that utilizes 3 x single-axis joystick module breakout boards to demonstrate three applications: (1) color and brightness control for an RGB LED, (2) position control for an SG90 servo motor, and (3) jogging speed and direction control for a NEMA 17 stepper motor using a TMC2208 stepper motor driver breakout board with an Arduino Nano.
Single-axis joysticks have historically been out of reach for hobbyists due to their large size and high cost, and while dual-axis joysticks are ubiquitous and commonly available, sometimes a user just wants to control a single axis. For example:
Controlling the light output level from an LED
Setting the angle of a rudder, airfoil, or RC car's steering angle for hobbyist projects using a low-cost SG90 servo motor
Jogging the position of a stepper motor on a DIY CNC machine
In this article, I share a demo unit that utilizes 3 x single-axis joystick module breakout boards to demonstrate these three applications!
Disclosure: Some of the links in this article are affiliate links. This means that, at zero cost to you, I will earn an affiliate commission if you click through the link and finalize a purchase.
2
Electrical Hardware
Solder the 22 AWG hookup wire to provide power (VCC, 5V) and GND to each of the three single-axis joysticks in parallel. Run one wire to each of the signal pads on each single-axis joystick board, and solder all 5 x wires to the aviation connector mounted on the side wall of the demo enclosure.
Build the breadboard circuit for the Arduino Nano clone board as shown in the image. The pin connections leading to the Arduino are as follows:
D2: LED Red
D3: LED Green
D4: LED Blue
D5: Servo PWM Signal
D7: TMC2208 STEP
D8: TMC2208 DIR
A0: Joystick 1 Signal
A1: Joystick 2 Signal
A2: Joystick 3 Signal
The Arduino Nano receives its 5V power from its USB port, which you can connect to a 5VDC external power supply, or to a typical PC/laptop USB port. The stepper motor is run off an external 12VDC power supply, and controlled using the TMC2208 stepper motor driver. Take care not to connect 12V positive power to any of the Arduino pins, or you risk damaging the Arduino!
3
Mechanical Hardware
The demo unit was created by laser-cutting sheets of 1/8" thick black acrylic. The DXF file used to create the laser cutting files was made using Autodesk Fusion 360. The side wall of the demo enclosure was 3D printed using black PLA filament, and then M3 threaded inserted were installed around the top and bottom rims using a standard soldering iron. Some screw caps were also printed using black PLA filament for the demo unit to rest on. The top 3 x joystick caps were designed in Autodesk Fusion 360 and printed using the same PLA filament, and they were designed to be press-fit onto the joystick handles.
The three styles of joystick I demonstrate here are:
Paddle type, for controlling the color and brightness of the RGB LED
Cup/trigger type, for controlling the position of the servo motor, e.g. for hobbyist RC boats, planes, and vehicles
Thumbstick type, used for jogging the position of a stepper, brushed DC, or BLDC motor
The top and bottom laser-cut acrylic sheets are fastened to the 3D-printed enclosure wall using M3 screws, and M2 standoffs + screws and nuts secure the 3 x joysticks to the underside of the top face of the demo unit. A 5-pin aviation connector is mounted to the side of the demo's printed enclosure wall.
