ESP-OS
A simple OS for ESP8266 and Arduino
0 followers
An operating system that is designed for microcontrollers, specifically for ESP8266 and Arduino. Written in C++. It is recommended to use PuTTY as a serial interface.
Requirements
- Arduino IDE
- A microcontroller
Compatibility
- Tested on ESP8266 and Arduino Uno R4 Wifi
- It may be necessary to make minor adjustments if you want to run it on different microcontrollers.
Programs:
- SysInfo: View information about the system.
- Calculator: A simple calculator.
- Direct Syscall: Execute system calls directly.
Simple task scheduler:
Task scheduler allows you to create and schedule tasks, with different priorities, for example, blinking an led(built-in in the io driver). Task scheduler also allows you to kill tasks by pid.
Task priority levels:
- 0 - Highest priority, used for critical tasks
- 1 - Very high priority, used for important tasks, for example in calculations
- 2 - High priority, used for normal tasks that require frequent use
- 3-4 - Higher than normal priority, use for less frequent tasks
- 5 - Normal priority, used for normal tasks
- 6-10 - Lower priority, used for example blinking a led
Check out the GitHub for the latest versions.
I'm not a professional and some information could be wrong!
esp_os_arduino-v1.1.0.zip
Version for Arduino.
x-zip-compressed - 8.78 kB - 03/29/2024 at 21:27
Download
esp_os-release-v1.1.0.zip
Latest version of ESP-OS.
x-zip-compressed - 8.67 kB - 03/28/2024 at 23:13
Download
View project log
  • 1
    Download the version
    Download the version that you want from Releases.
  • 2
    Extract the zip
    Extract the zip file to your desired location.
  • 3
    Open Arduino IDE and upload
    Open the "esp_os.ino" from the extracted zip. All required files are in the "src" folder. Here's a tutorial if you haven't installed the ESP8266 library yet. Select your board port for example I have COM4 and then click upload. Done! Don't forget to set the serial monitor baud rate to 115200 or it won't function properly.
View all 3 instructions
