Multi-Meter Pulse Reader with ESP32-S3 and LTE
Read pulse output from power meters ( or other ) than send to the internet via LTE connection
This system supports up to 10 power meters with pulse output. The ESP32-S3 uses interrupt handlers to efficiently process the pulse signals. It then calculates the actual consumption for each meter by counting the pulses. Finally, the values are sent to an online database via an LTE connection. SMS commands provide control and configuration.
Introduction
In today's world, gaining control over energy consumption is a top priority. There are two main methods for monitoring domestic energy use:
1. Current Phase Measurement using a Clamp Meter. This method utilizes clamps that attach around a single conductor to measure current flow. It's a non-intrusive approach, meaning it doesn't require interrupting the power supply.
2. In-Line Meters: These meters are installed directly into the electrical circuit, interrupting one or more phases to measure current. While effective, they require professional installation and can be less scalable for multiple circuits.
Both methods often offer an interface with a pulse output, where the pulse frequency is directly proportional to the real-time energy consumption. This allows for easy data collection and analysis.
This project provides a solution for collecting pulses from multiple meters and sending them to a database for further analysis. Additionally, since pulse outputs are also used by other types of metering systems (gas, water, etc.), this system can be easily expanded to support them.
The project
The core of the project is an ESP32-S3 microcontroller, which receives and collects pulse data from meters. After a quick online search, I couldn't find much info on the type of pulse the meters output. So, since I wasn't sure, I did some tests with an oscilloscope and a load (a hair dryer) to generate the pulses. ( however this awesome project helped me a lot openenergymonitor )
Using an oscilloscope connected to the meter, background noise can be seen when the output is not active (floating output), while a short circuit can be observed when the pulse occurs.
Clean output signal seen from oscilloscope
Testing the meter's output
Open drain circuit configuration
Awesome! It seems like each meter has an open-drain output style (I hope also isolate from live circuit). This is super cool because we can hook it right up to the ESP32 and just using a pull-up resistor. This will give us a nice falling edge pulse that we can easily count using interrupts.
For the moment I decided to realize a demo project using a protoboard, just to test the system as a whole before realizing the final pcb. The test circuit includes a DevKit ESP32-S3, a Simcom A7670C module and connectors. That's ALL!! I decide to use internal pull-up resistors of ESP32, so no other components are involed. In some cases, the internal pull-up might not be sufficient, but for the moment It works...
This is the resullt signal when connecting esp32 with pull-up resistor. Now it’s a piece of cake!
  • Box enclosure
    Davide06/24/2024 at 09:10 0 comments
    This is the DIN rail box I designed to house the board
  • Hardware ready!
    Davide06/05/2024 at 09:15 0 comments
    I've successfully completed the first prototype of the project, incorporating all the functionalities I require for the time being. As soon as I have all the components and boards in hand, I'll proceed with the initial testing phase.
    • Up to 10 input signal
    • Input protection against ESD
    • ESP32 S3, 2.4 GHz Wi-Fi and Bluetooth 5
    • Protected USB-C for power and debug
    • 5v power input regulated with high efficiency step down converter
    • A7670 LTE/GNSS module
    • Support standard SIM card (botton side) or MFF2 form format
    • Led RGB with integrated controller and side view
View all 2 project logs
