• Catalogue page
    Keith05/09/2024 at 22:31 0 comments
    This double Eurocard processor offers unique flexibility for real-time systems designers: a high-performance 68020 VMEbus CPU with hardware suited to cost-effective implementation of embedded systems, coupled with an additional interface to STEbus on the outer rows of P2. This secondary bus provides the option of utilising the low-cost single Eurocard STEbus board system.
    On-board features include a 68020 CPU with cache running at 16-, 20- or 25-MHz, a socket for the 68881 maths co-processor, up to 2 Mbytes of zero wait-state dynamic RAM dual-ported to the VMEbus, 32 Kbytes of battery-backed static RAM dual-ported to the STEbus, two serial ports with access via either the front panel or an on- board 10-way header connector, two EPROM sockets jumper-selectable for up to 256 Kbyte devices, watchdog timer and battery-backed real-time clock.
    The VMEbus interface supports 8, 16 and 32-bit data transfers with an addressing capability up to 4Gbytes, and includes a single-level arbiter, source for system clock and reset. Interrupts can be link-selected and prioritised from the real-time clock, serial ports, watchdog timer, VME and STE buses, BERR time-out and AC FAIL.
    Four LEDs on the front panel provide indication of SYSFAIL and RUN/HALT status, and two user programmable diagnostics. VSC020T is designed for a high degree of inter-compatibility with Arcom's STEbus 68020 processor, SC020T. For many applications this allows target system hardware to be very easily upsized/downsized as the full application requirements emerge during the design cycle, eliminating one of the commonest and most costly problems of real-time systems design.
    Comprehensive software support includes the multi-tasking ROMable operating system OS-9/68K, and a complete range of I/O board drivers.
    VMEbus Interface
    A32/24/16, D32/16/8 (E0) AM 09, 0A, 0D, 0E, 29, 2D, 39, 3A, 3D, 3E as master. A24, D16, D8 (E0) as slave.
    STEbus Interface
    Master and slave
    Power consumption
    Typ 4.8A @ 5V, 50mA @ +12V
    Ordering Information
    VSC020T-16    16MHz CPU, 1Mb DRAM
    VSC020T-20    20MHz CPU, 1Mb DRAM
    VSC020T-25    25MHz CPU, 1Mb DRAM
    VSC020T-162   16MHz CPU, 2Mb DRAM
    VSC020T-202   20MHz CPU, 2Mb DRAM
    VSC020T-252   25MHz CPU, 2Mb DRAM
    Features:
    • 16, 20 or 25MHz 68020 CPU with 64 long word cache
    • 1 or 2Mb zero wait-state DRAM; 32-bit organised,
      1Mb dual-ported to VMEbus, top 32Kb used as inter-bus mailbox
    • Two EPROM sockets (16-bit organised) for up to
      512Kb EPROM
      32Kb battery-backed static RAM dual-ported to STEbus
    • 68881 co-processor socket
    • Watchdog timer
    • Battery-backed real-time clock
    • Comprehensive interrupt scheme
    • VMEbus interface
    • STEbus interface
