Ratchet Wheel For Laces
We're going to create a systeme for tying shoelaces with a easy way. This will be a ratchet wheel system that allows users to tie their shoe
The laces system is gonna be composed of four main pieces : a base, a ratchet wheel, a spool and a rod. To tighten his laces, Diego just has to turn the wheel in one direction so that the laces wrap around. And to untie them, he'll have to lift the hook, which will release the tension and the laces.
We want to help diego tie his shoelaces more easily.
Inspired by the lacing system on boa snowboard boots. We began by investigating how ratchet wheels work, and obtained a 3d model.
Once that was done
But before trying out this model on a 3d printer, we made drawings and 3d models using cardboard.
The cardboard was too fragile to withstand the force exerted by the rubber band, so we replaced the cardboard components with wooden ones.
after a few modifications, the ratchet-wheel mechanism works very well.
JPEG Image - 3.12 MB - 06/11/2024 at 14:51
Preview
JPEG Image - 2.21 MB - 05/21/2024 at 14:12
Preview
JPEG Image - 1.78 MB - 05/21/2024 at 14:12
Preview
JPEG Image - 68.28 kB - 05/21/2024 at 14:12
Preview
JPEG Image - 63.10 kB - 05/21/2024 at 14:12
Preview
View all 7 files
  • 1 × The rod To connect all the components
  • 1 × The base To maintain the overall
  • 1 × The ratchet wheel To make the rotation movement
  • 1 × The spool To wrap the laces around
  • 21/05/2024
    ensonvotrung • 05/21/2024 at 14:52 • 0 comments
    3d print is done. Adding most off the files and the logs to hackaday. Assembling the 3d printed pieces for the final prototype.
  • 14/05/2024
    Finished the 3d schematics of all the components. We assembled prototype out of cardboard and then out of wood. Next step is gonna be 3d printing.
  • 07/05/2024
    ensonvotrung • 05/21/2024 at 14:28 • 0 comments
    Finding the idea out of a snowboard shoes inspiration of the brand boa. We did researches about the system needed and the size of it so we asked a lot of questions to Diego and measured his shoes.
View all 3 project logs
