CYBER.PY Zero-Three
A cyber desk project with a Pi4 and wide LED screen jampacked in a custom 3D printed enclosure.
Public Chat
This is CYBER.PY Zero-Three, a Cyberdesk-themed Raspberry Pi PC that is equipped with the Waveshare 7.9-inch ultra-wide HDMI display. This is basically another installment of my previous Cyber.PY projects, which you can see by visiting the links below. https://www.hackster.io/Arnov_Sharma_makes/cyber-py-zero-one-339846 https://www.hackster.io/Arnov_Sharma_makes/cyber-py-zero-two-fdd889 First, the whole design was modeled in Fusion360. Then it was 3D printed with an Ender 3 printer in a two-color scheme. The Raspberry Pi 4 serves as the project's brain, but it can be swapped with a Raspberry Pi 5 or even a lower version because all of the fittings are interchangeable and compatible with all Pi models.
This configuration is powerful and capable of running everything we throw at it thanks to the Pi4; for instance, Minecraft Pi Edition Modded is running on this setup.
Installing Pi-apps will allow you to add a ton of programs to this setup, such as games like DOOM and emulators like PPSSPP. We even personalized our Pi to look like a Mac by using a custom Mac OS theme.
In order to expand the Pi4's IO ports, we have also added a USB hub to this device.
Additionally, the display we're using is a touch screen.
3D Design
In order to model the 7.9-inch display, we first had to build the body of the model. To do this, we measured the display manually and created the model.
Then, as the display has PCB standoffs placed on it especially for mounting the Raspberry Pi, the Raspberry Pi 4 Model was imported into the design and placed on the back of the display.
whole model was then designed around the screen.
The design was divided into two main parts: the Main Body and the Back lid.
The main body holds the screen and Pi arrangement from the inside; The exterior features a curved screen front cover part that we made after the front appearances of vintage CRT monitors;
We modeled the front face by taking influence from CRT monitors, which shared similar designs. To enable us to print the main body and the front face using various colors of filament, we separated the two pieces. This will provide contrast to the model and improve its aesthetic appeal.
To enhance the visual appeal, we modeled a second part for the main body and created an opening that is filled with an orange-printed part. We named the following component the slot part.
I have combined two distinct pieces with two color tones across the model to create a single assembly, to enhance the visual appeal and design of the project.
The Base Lid part is modeled with a large opening in the middle. In this opening, we will add a grill for air ventilation, This grill part is printed from transparent PLA, and the lid itself is printed with orange PLA.
We have modeled two screen holders inside the main body that, when installed, will hold the screen and Pi assembly in place.
We also added a USB hub, which is installed on the left side of the model, since we could not access the USB ports on the Raspberry Pi because it was mounted in the middle.
On the right side, we have added a DC Barrel Jack connector for powering the Pi and the display.
There's also a switch added on the left side for turning power ON or OFF.
Once the model was finished, we took the entire design, rotated it by 13 degrees, and created a stand to support the entire model at a 13-degree tilt. We took this step since all of the old monitors had a slight tilt.
3D-printed parts
Following the design's completion, we exported each component into a mesh file and used two filaments—transparent PLA and orange PLA—to 3D print every part.
  • Main Body: Transparent PLA with a 1mm nozzle and 0.3mm layer height
  • Front Cover: Orange PLA with a 0.6mm nozzle and 0.2mm layer height
  • Back Lid: Orange PLA with a 1mm nozzle and 0.3mm layer height
  • Back Lid Grill: Transparent PLA with a 0.6mm nozzle and 0.2mm layer height
  • Screen Holder 1: Transparent PLA with a 0.6mm nozzle and 0.2mm layer height
  • Screen Holder 2: Transparent PLA with a 0.6mm nozzle and 0.2mm layer height
  • IO Port Cover: Orange PLA with a 0.6mm nozzle and 0.2mm layer height
  • Slot Part: Orange PLA with a 0.6mm Nozzle and 0.2m layer height
We use the above settings to print each part with our Ender 3 printer.
7.9-inch HDMI LCD DISPLAY
The Ultra Wide 7.9-inch HDMI Display, made by Waveshare, is the main component of this project.
This screen is fantastic; it has a 400x1280 pixel resolution and is incredibly bright. By holding down the ON/OFF button for an extended period of time, you can adjust the screen's brightness.
This is a 5-point capacitive torch screen that has a 6H hardness tempered glass panel.
This...
CYBER PI v15.step
step - 15.99 MB - 06/24/2024 at 09:50
Download
CYBERPI3.f3d
fusion - 10.64 MB - 06/24/2024 at 09:50
Download
Main Body.stl
Standard Tesselated Geometry - 428.60 kB - 06/24/2024 at 09:49
Download
BACK LID GRILL.stl
Standard Tesselated Geometry - 248.62 kB - 06/24/2024 at 09:49
Download
SCREEN HOLDER01.stl
Standard Tesselated Geometry - 101.84 kB - 06/24/2024 at 09:49
Download
View all 12 files
  • 1
    Main Body Assembly
    • Super glue is initially applied to the main body, and then the front face is positioned in its proper position to begin the assembly procedure.
    • In a similar manner, we inserted the slot section from the interior of the main body, and it fit properly. Superglue is used to permanently attach it to the main body in order to ensure integrity.
    • Next, we added M2.5 screw-threaded inserts into the hole provided on the main body, We used a soldering iron paired with a TS100 TIP Adaptor Kit that we obtained from PCBWAY Giftshop. Using the soldering iron, pick and position the threaded insert over the hole, then push it down until it heats up and slides into place.
    • At last, we added the DC Barrel Jack in its place on the main body.
  • 2
    Adding Screen and Pi Assembly with Main Body
    • The Display-Raspberry Pi assembly is now picked up and placed inside the main body's screen location. Supporting ribs are designed all around the display to keep it in place.
    • We use screen holders, which are positioned in their proper locations and then permanently fastened with two M2 screws each, to hold the display in place.
  • 3
    USB Hub Assembly
    • Using a USB Hub bare circuit that we salvaged from an outdated USB Hub product, we are able to connect a mouse and keyboard to a Raspberry Pi. The hub features three USB 2.0 ports.
    • Screen Holder 1 has four mounting holes on it that are used to secure the USB Hub circuit in place when it is positioned over it.
    • We then use four M2 screws to secure the USB hub in its place.
    • Finally, we connect the Raspberry Pi USB port to the hub's USB cable.
View all 9 instructions
