Adafruit_399_spec_sheet.pdfDatasheet for the LCD. I wound up referencing this a lot, especially while defining the interface connections between the Pi and the LCD.Adobe Portable Document Format - 330.68 kB - 03/13/2017 at 21:24 |
Wiring table.JPGTable showing which pins on the Raspberry Pi GPIO header are connected to which pins on the LCD, and which are connected to buttonsJPEG Image - 79.49 kB - 03/13/2017 at 20:58 |
L4D2 Base w Letters Rev 4.stl3D model file of L4D2 trophy and LCD housingStandard Tesselated Geometry - 163.17 kB - 03/13/2017 at 05:39 |
