Sensor Testing
04/09/2017 at 06:25 • 0 commentsProgress on sensors is finally being made. Or any effort is now being made to be precise. It now make delicious numbers appear on screen. That and the screen was replaced with an SPI based one that allows for fast updates. Serial doesn't like being hurried, the Grideye data does't like to be slow.
GridEye Works...Mostly
02/26/2017 at 06:54 • 0 commentsThe Grideye Sensor is now spitting out temperature data! Yes it looks scary. Yes I'm surprised it is working. Now I have to make it go from numbers to pretty colorful pixels or no one will care what it does.
The lighter is for.....scientific testing..... and it doesn't work very well when low on fluid. (Obvious man)
It might work
02/23/2017 at 06:25 • 0 commentsHow do you try to make SMD parts work where a circuit board won't fit? Solder tiny wires to them and hope it works.
Of course it will.
Might.
Maybe.
The Pins are for testing.
Some more sensors
02/21/2017 at 03:42 • 0 commentsSensors! More Sensors. Why? Why Not! Why is so many sensors hard to fit? Why don't you just marry no sensors if you love it so much? In fact why don't you invent a safety sensor that keeps you from getting hit in the butt from the door on your way out because you are fire.....
OLED Works
02/10/2017 at 07:35 • 0 commentsGot the OLED Working
