Window Fan Controller
Back to overview
This project was created so I do not have to turn my window box fan off at night when it gets too cold.
mababaar wrote 06/18/2015 at 17:51 point
thank your for your feedback
i`m still wating to the sensors.....
rockfishon wrote 06/18/2015 at 17:09 point
Start your project and let me know what it is called so I can comment more in detail.
Just a suggestion - you might want to add some checks to make sure the fan is not on while the humidifier is on.
mababaar wrote 06/18/2015 at 17:03 point
Hello
I have found at hackaday, your great code.
I would use it for my “greenhouse” project, but I am a beginner to program the Arduino…..
I would like to implement additional features
1                    if the temp are higher          -relays 1 are aktiv ( Fan)                              (32 °C)
2                    if the temp are  lower       -relays 2 are aktiv (heating)               (20 °C)
3                    if the humidity are higher   -relays 1 are aktiv (Fan)                               (90%)
4                    if the humidity are lower    -relays 3 are aktiv (humidifier)  (65%)
hysterese temp 4°C `
hysterese  humidity 15%
set points should be adjustable via keypad
I would be pleased if you would support me a bit
The next steps could be…….:
-light controll (Timer)                    relays 4
-soil moisture                                   relay 5 (Waterpump)
Best Regards
Mark
