Raspberry Pi Photo Frames have been done to death. YAPSFrame is customized for my needs. Things I wanted: Cheap hardware, my software, use my existing Windows Shared directory of all our photos. Things that would be cool: a clock, rotate images appropriately, show the weather at home and in Tahoe, show our upcoming family calendar, use Alexa to move to next photo or mark as favorite "Alexa, next photo"!
Google calendar integration is live in the kitchen!
I started with the Google Calendar API quickstart https://developers.google.com/google-apps/calendar/quickstart/python and got that running on it's own. That was pretty straight forward, just pay attention to the credentials recipe on that page. Once I got the API running on my dev machine, I took a close look at SmartHouse implementation of the news feed. The way I wanted to display our calendar items is similar to how they did the news stories. I started with that framework and pretty much just plugged in the relevant sections of the quickstart.py code.
I didn't really like how the date was displayed, so I google-fu ed a function to display the date as "March 5th" "May 2nd" etc.
When displaying a landscape photo, there really isn't too much space on the right side. Instead of changing the font size, I just hide the upcoming calendar events when displaying a landscape photo. How I hacked getting a pointer to the switch function seems very kludgy, maybe some pythonic savant can refactor that for me. Eventually, I'd like to put the weather in that tight vertical space.
I've hardcoded the time between updates of the calendar to be 30 minutes.
In Rev 1, I used the image width and height that ImageTk returned to determine whether it was a portrait or landscape photo. If width was the larger = landscape, else = portrait. Once I knew it was portrait, then I knew to scale the image so that the height matched the frame height. If it was landscape, then I scaled using the width as the constraint.
Using this method works great for landscape photos. For portrait photos, the initial success rate was probably about 1/3. I'd walk by the kitchen table to see my wife smiling with her head tilted over on it's side looking at a photo rotated 90 degrees from where it should be. Not bad, but not good enough.
Version 2 uses EXIF tags to orient the photos. I may still add OpenCV for images that don't have an orientation EXIF tag, but for now I've gone from 2 of 3 portrait photos being incorrectly displayed to 9 out 10 being good. Big improvement for not much CPU cycles.
After figuring out a hack to read from my Windows Our Pictures share, I installed the first version on the actually Pi and let it rip. Pretty quickly, I realized that I wanted some more configuration. I added a configuration for length of time each photo shows before flipping to the next photo. I also added a list of directories within the Our Photos directory that I don't want to display or dig through looking for photos.
Family was pretty happy to see some of the old photos roll by. The Raspberry Pi, old monitor, keyboard and mouse were granted another few days on the kitchen table as long as they kept flipping puppy and baby photos!
I'm writing this a couple of weeks after the fact. Really, what I wanted to do was to just mount my Windows Share on the Pi as just another directory. With my Ubuntu instance it was done after about 5 minutes of Googling. "Mount windows share on ubuntu"
But when I went to do it on the PIXEL instance...not so much. Yes, it seems trivial, mount -t cifs yada yada. It didn't work for me. Maybe something with my Windows setup, maybe something with the PIXEL i386 kernel (that's what I concluded, but when the googling got to "modprobe" I knew that I was in over my head/interest)
Anyway, the hack I fell back on was to use the smbconnection module in python. Even that was a bit of screwing around, but I got it all working.
One of the things you might notice in the code is that I read the file from the Windows Share into an IO stream. The example for SMBConnection actually writes to a file. I did not want to write to a file...I'm thinking that if every time we look at a new image we'd have to write that image from the share to the Pi's disk would be bad for the long term heath of the Raspberry Pi's sd card. I used an IO stream and read the image file from the Share into memory then loaded the image into TKinter's ImageTk module from that memory.
Windows is my daily driver. I'm pretty horrible at Linux, but can get around. So for web projects I typically spin up an Ubuntu instance on Virtual Box. For this project, I started from HackerHouseYT's awesome Smart Mirror project https://hackaday.io/project/13466-raspberry-pi-smart-mirror I cloned the git repository and got it running on Ubuntu pretty quickly. So now I needed to get it up on a Pi.
The Pi I've been using is sitting on the kitchen table hooked up to a keyboard, mouse and monitor. It's not a comfy place, I'd rather use my desk. Desk space is limited and didn't really have space for a third monitor, second keyboard...too lazy to disconnect...reconnect. Hey, can I run a Virtual Box of Raspian on my Windows machine?
Cool, now I can code either in Ubuntu, deploy to the PIXEL i386 vm and make sure it works and figure out what additional dependencies I might need on PIXEL. Then once it's all working, I can sit down at the kitchen table and deploy to the real PI.
So far, the i386 PIXEL is 95% the same as the PIXEL running on the real Pi.
To expand on what I wrote in the description. I've long had a server in the house with a network share to keep all the family data. We've got thousands, possibly tens of thousands of photos in the Our Photos directory. Many of them great, and we just don't see them very often. I've long wanted to have display in the house that showed our photos. I've bought a few photo frames. Some of them used a memory stick, some of them would pull off of a Flickr or Dropbox folder. Those are fine, but we've got 30 to 40 gigs of photos and putting them up on the web is a task I neither want to tackle, nor pay for the storage.
So, I wanted a photo frame that connected via the home network to the shared drive and pulled the photos from there. I've thought of repurposing an old laptop, but never found the time.
With Raspberry Pi, I of course saw a great hardware solution. Just a monitor and a single board. All I needed was the time...
Once I got into it, I thought of other things I would want.
1 - Clock
2 - Local weather and forecast. Ideally for home and for Tahoe
3 - Family Calendar
Other stuff that would be cool.
Ability to favorite certain photos so that they appeared more often. Likewise ability to down vote certain photos. Ability to recognize photos that needed to be rotated and automatically rotate them.
