Runs an empty C program!
A project log for Atmel SAMC breakout
Simple breakout board for Atmel's SAMC 5V ARM chip.
westfwWestfW 08/05/2019 at 03:120 Comments
After fiddling with tools a bit (it looks like neither AS7 nor MPLABX 5.1 is quite up to using a PICKit4 with SAMC21), I have the board responding, have uploaded an empty C program, and can single-step through the C runtime startup code.
(Using (upgraded) MPLABX 5.25 and the PICKit4, on MacOS...)
So that's pretty significant!  Next up, Blink!
