This project provides Eagle schematics and PCB for a Shield compatible with Arduino UNO. It features:
  • PS/2 keyboard connector
  • USB-A female, alternative mount for USB keyboards that can revert to PS/2 mode
  • SD Card Connector
  • Micro SD (alternative mount) Card Connector
  • Dual RCA connector for Audio/Video
  • P2 Stereo Jack (alternative mount) for Audio/Video
  • Infrared Receiver
  • Reset Button
The connectors were disposed so all the wired connections are on the same side while the SD socket and the Infrared receiver are on the opposite side. This should make the device more easy to be used and hence easier to put in a box.
The board was manually routed.
#Zorkduino was created by @rossumur For more info go to the #Zorkduino project page
