More Fuel Injector Measurements
A project log for Turbo Lexus IS200 (on the cheap!)
Improving the performance of an IS200. Goal - Under £1000
roryRory 04/17/2017 at 10:250 Comments
My girlfriend took me for a spirited drive to test the maximum duty cycle of the injectors. Full throttle at 6k RPM results in a duty cycle of 62%
This leaves me 38% available which probably isn't enough to feed the engine on full boost but will get me started. I can always install a rising rate fuel pressure regulator to get a bit more flow.
