SPM64 kills the optical inch (for VIS-IR)
A project log for The Optical Inch
A tiny, ultra low profile wideband spectrometer for everyday needs (test lamps for color temperature & CRI, UV-A /UV-B dosimetry, ...)
helgehelge 02/16/2017 at 09:410 Comments
What's more important - achieving a goal or seeing a project through? You decide. ESPROS obviously managed to get a simple (diffraction based?) filter matrix slapped onto a camera sensor, making a cost effective and elegant device called Viavi.
Need UV A/B as well? Grab a VEML6075.
Meanwhile the Optical Inch will continue its journey with an LED array and Si PIN diodes for in-situ x-ray imaging. Stay tuned.
https://www.espros.com/photonics/spm64/
