Gorilla Solar - Window 1kW array to 120V AC!
Use your windows sun light to run your electrical meter backwards!
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Have you ever wanted to take part in the solar revolution but live in temporary place? Gorilla solar is your ticket you running your meter backwards and benefit from the power of the sun. The system simply sits out your window and plugs right into your wall outlet. Sound simple right?! That's because it is!
