JPEG Image - 417.06 kB - 10/18/2017 at 12:19 |
JTAG adapter board 04.pcbLimeSDR 'JTAG' adapter for connecting SPI bus to Arduino 3.3v Due. The pinout connectors on the LimeSDR are extremely small and almost impossible to get a reliable connection with 'bare wires'. The only sure way is to get this PCB made.pcb - 88.00 kB - 10/18/2017 at 12:07 |
JTAG adapter board 04.zipGerber files for abovex-zip-compressed - 10.58 kB - 10/18/2017 at 12:07 |
Cell_Phone_Repeater_03.inoCode for Arduino Uno.ino - 8.56 kB - 10/13/2017 at 11:17 |
Full Duplex 16.pcbPCB design opens with 'Design Spark' software.pcb - 261.50 kB - 10/13/2017 at 11:14 |
x-zip-compressed - 142.84 kB - 10/13/2017 at 11:14 |
TxSine780M.iniUse LimeSDR to generate and transmit a sine wave at 780 MHz for testing band pass filters.ini - 16.76 kB - 10/10/2017 at 10:18 |
VNA Block Diagram 01.jpghttp://event.on24.com/eventRegistration/console/EventConsoleNG.jsp?uimode=nextgeneration&eventid=1280495&sessionid=1&username=&partnerref=&format=fhaudio&mobile=false&flashsupportedmobiledevice=false&helpcenter=false&key=6157B1F5FE7B64D97B1E9FA339F3E69E&text_language_id=en&playerwidth=1024&playerheight=768&overwritelobby=y&eventuserid=178743029&contenttype=A&mediametricsessionid=143583132&mediametricid=1853033&usercd=178743029&mode=launch#JPEG Image - 168.50 kB - 09/04/2017 at 09:56 |
Signal_generator_01.inoTurn the LimeSDR into a signal generator using an Arduino Due.ino - 28.92 kB - 08/19/2017 at 08:57 |
Adobe Portable Document Format - 49.01 kB - 07/23/2017 at 14:00 |
document - 15.15 kB - 07/23/2017 at 14:00 |
License.txtCreative Commons Attribution-ShareAlike 4.0 International Public Licenseplain - 13.86 kB - 07/23/2017 at 08:22 |
sheet - 16.17 kB - 07/22/2017 at 16:30 |
Cell Phone Signal Booster 01.pcbOpens with 'Design Spark' PCB software (Free).pcb - 246.00 kB - 07/22/2017 at 09:22 |
JPEG Image - 818.24 kB - 07/22/2017 at 09:19 |
Adobe Portable Document Format - 787.87 kB - 07/21/2017 at 14:01 |
TQM879028.pdfVariable gain amplifierAdobe Portable Document Format - 1.25 MB - 07/21/2017 at 14:00 |
QPL9065.pdfLow noise amplifierAdobe Portable Document Format - 2.47 MB - 07/21/2017 at 13:59 |
sheet - 15.83 kB - 07/21/2017 at 13:52 |
sheet - 81.76 kB - 07/03/2017 at 16:55 |
ino - 34.72 kB - 07/03/2017 at 16:37 |
rbf - 548.98 kB - 07/03/2017 at 16:35 |
rbf - 549.84 kB - 07/03/2017 at 16:35 |
SPI control of TQM879028.txtArduino fileplain - 809.00 bytes - 06/13/2017 at 19:17 |
SPI control of LimeSDR.txtArduino fileplain - 19.83 kB - 06/13/2017 at 19:17 |
application/pdf - 1.95 MB - 07/10/2017 at 15:26 |
Simple_806MHz_Repeat 03.iniUse with LimeSDR in Limesuite software.ini - 16.57 kB - 06/02/2017 at 06:32 |
Band_20_Repeater_02.iniFinally I have produced a LimeSuite .ini for the LimeSDR that actually 'seems' to work! Probably needs some fine tuning.ini - 16.57 kB - 04/18/2017 at 13:08 |
Simple_806MHz_Bandwidth_30_Repeat_03.iniHere I attempted to re-transmit received frequencies at centre frequency 806MHz with a bandwidth of 30MHz. (Band 20 base Tx LTE). Although I got a nice Rx spectrum in the LimeSuite FFT, my second SDR rig failed to notice successful transmission :(ini - 16.57 kB - 04/18/2017 at 09:32 |
Simple 806MHz repeat 01.pothosA simple repeater sketch was set up in Pothos and 'Scooped' up in Limesuite and a second SDR was used to prove that it worked.pothos - 101.45 kB - 04/16/2017 at 18:07 |
Simple_806MHz_Repeat 01.iniA simple repeater sketch was set up in Pothos and 'Scooped' up in Limesuite and a second SDR was used to prove that it worked.ini - 16.57 kB - 04/16/2017 at 18:04 |
pothos - 182.29 kB - 04/16/2017 at 16:29 |
ini - 16.57 kB - 04/16/2017 at 16:24 |
duplexer-04.gifAnother duplexer test, this time with a stronger signal. This scenario showed a better signal to noise ratio with nice clean lines.Graphics Interchange Format - 7.49 MB - 04/14/2017 at 18:04 |
USD020A Datasheet.pdfBand 20 LTE duplexerAdobe Portable Document Format - 458.22 kB - 04/14/2017 at 15:18 |
Test MIMO 02.pothosTesting the MIMO capabilities of the LimeSDR - Channels 1 and 2 simultaneous receive. Revised sample rates and clock speed. Adjusting frequencies on channel B continues to only affect channel A .... FAIL!pothos - 174.97 kB - 04/10/2017 at 08:51 |
Test MIMO 01.pothosTesting the MIMO capabilities of the LimeSDR - Channels 1 and 2 simultaneous receive.pothos - 137.46 kB - 04/09/2017 at 15:27 |
LimeTxRxDemo.pothosVery simple Receive and Transmit for LimeSDRpothos - 91.68 kB - 04/06/2017 at 14:40 |
simple_fm_radio_02_WORKING.pothosVery nice FM radio that works 'out of the box' on LimeSDR.pothos - 135.02 kB - 04/06/2017 at 14:36 |
FM_RADIO_08.grcWorking GNU radio FM receiver - sound quality is 'variable'.grc - 50.06 kB - 04/06/2017 at 14:34 |
FM Re-Transmit 01.pothosTune into an FM radio station and transmit it again 1 MHz up from the original frequency, using the LimeSDR.pothos - 177.07 kB - 04/05/2017 at 16:49 |
