Aquarium feeder
Simple plywood aqurium feeder with 9 slots to feed the fishes controlled with Arduino.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I made this to feed my shrimps while i am away. It has plywood three layers, with one that has 9 holes that can be loaded with shrimp food. If you like to have more details, just ping me. Old version (RELEASE/2.0) was using arduino UNO and serial terminal to configure the feeding pace. Current version (master) is done with Arduino Mini and small board, that has new features: * A button to reset the feeding cycle * A 3-hole jumper to select the feeding pace, interpretted as binary number * 12h. With no jumper in place its in 'test mode' running one hole in 30s. The new hardware also features a usb-micro connector to power the thing, since the mini board does not have usb-serial-connector to provide the power.
