Technology used:
- WordPress for this content site
- Likely will use the Node full stack: Angular 4 Meteor MongoDB Ionic base
- Two factor enabled RealMe accounts
- Linux based servers but portable to other platforms due to use of Node
- Github for hosting the code
- Looking into use of Docker
- Need help with the block-chain and authentication parts presently
