DigiPot for PotBelly
A board which replaces the standard analogue potentiometer on a PotBelly PWM with a digipot and a 5v LDO for high voltage vaping.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A requirement for my PotBelly PWM units (see moxbods group on facebook)to be able to run on 28-30v supply necessitated a LDO implementation, and I decided to at the same time add a digipot to the board.
The board can also be used as an LDO only if need be, as it has through holes for the standard potentiometer.
I had the boards produced by pcbway.com and they are excellent quality and finish.
