Software&Server_Diagram.jpgThis is a conceptual Workflow-like diagram for the software services and routines running on the server side.JPEG Image - 56.07 kB - 04/01/2017 at 11:37 |
Electronics_Diagram.jpgThis is a block design Diagram of all the electronics to be implemented. This is the design for the complete model introducing more ADCs and a serial bus communication between modules.JPEG Image - 55.64 kB - 04/01/2017 at 11:37 |
MultiChannelModules_Diagram.jpgThis is the block design diagram sketch for the Multi-channel Module. This module handles amplification as well as handling dc-bias and dc-coupling.JPEG Image - 40.58 kB - 04/01/2017 at 11:37 |
AnalogBoards_Diagram.jpgThis is the block design Diagram for the Analog Board Module. This Module takes care of anti-aliasing filters as well as ADC conversion and multiplexation of various signalsJPEG Image - 57.80 kB - 04/01/2017 at 11:37 |
FullPlatform_Diagram.jpgThis is the Full Conceptual diagram of the entire platform. It basically shows how the Electronics and SoftwareServer Diagrams connect to each other.JPEG Image - 54.20 kB - 04/01/2017 at 11:37 |
MainBoard_Diagram.jpgThis is the block design Diagram of the Main board. This board isolates the power supply and also charges a battery. The heart, a DSP (Teensy 3.2 right now), is here. It has isolated serial, WiFi, and possibly Bluetooth.JPEG Image - 49.55 kB - 04/01/2017 at 11:37 |
