sketch_wambat_mark2.inoThe "final" version, with all keys' assignments.ino - 21.07 kB - 04/29/2017 at 03:26 |
WAMBAT_Graphics.pngThe button reminder for the keyboard top.Portable Network Graphics (PNG) - 61.27 kB - 04/29/2017 at 03:25 |
Wiring.pngFinal wiring diagram.Note my $3 Arduino had defective pin 5, so I reassigned some lines around. Portable Network Graphics (PNG) - 158.29 kB - 04/29/2017 at 01:57 |
07_Label_Cut.ncUse 1/8 in tungsten single-flute end mill bit for cutting Plexiglass on CNCNetwork Common Data Form (NetCDF) - 1.66 kB - 04/25/2017 at 09:54 |
06_Label_Drill.ncUse 3 mm drill bit for drilling on CNCNetwork Common Data Form (NetCDF) - 393.00 bytes - 04/25/2017 at 09:54 |
05_Top_Plate_Cut.ncUse 1/8 in tungsten single-flute end mill bit for cutting Delrin on CNCNetwork Common Data Form (NetCDF) - 13.04 kB - 04/25/2017 at 09:54 |
04_Top_Plate_Drill.ncUse 3 mm drill bit for drilling on CNCNetwork Common Data Form (NetCDF) - 1.14 kB - 04/25/2017 at 09:54 |
03_Tray_Cut.ncUse 1/8 in tungsten single-flute end mill bit for cutting Delrin on CNCNetwork Common Data Form (NetCDF) - 834.00 bytes - 04/25/2017 at 09:54 |
02_Bottom_Plate_Cut.ncUse 1/8 in tungsten single-flute end mill bit for cutting Delrin on CNCNetwork Common Data Form (NetCDF) - 2.43 kB - 04/25/2017 at 09:54 |
01_Bottom_Plate_Drill.ncUse 3 mm drill bit for drilling on CNCNetwork Common Data Form (NetCDF) - 2.22 kB - 04/25/2017 at 09:54 |
Keys_WAMBAT_Mark_1.pdfLayout for WAMBAT Mark 1Adobe Portable Document Format - 35.09 kB - 04/15/2017 at 06:38 |
Key Layout Screen.pngScreen background for WAMBAT Mark 1Portable Network Graphics (PNG) - 71.09 kB - 04/15/2017 at 06:34 |
Layout_Mark_5.pdfLayout for GKOS Mark 5Adobe Portable Document Format - 35.48 kB - 04/15/2017 at 06:20 |
sketch_gkos_mark5.inoThis sketch implements the code for modified GKOS input layout;Note this is not a "True" GKOS, as the frequent keys have been reassigned to the index and middle fingers. The code is for Leonardo-compatibles only! v 1.0 3-Apr-17 ino - 20.93 kB - 04/15/2017 at 06:04 |
sketch_acrus.inoThe initial proof of concept sketch implements the Leonardo code.v 1.0 1-Apr-17 ino - 15.19 kB - 04/03/2017 at 08:00 |
