Wifi Controlled Intel Edison Bot
Create an Intel Edison Robot which can be controlled using a Python script
0 followers
This bot can be controlled via wifi using an SSH connection to the Intel Edison or you can control it via a python script which will start as a service when you power your Intel Edison.
You can access the code here https://github.com/san45/Intel-Edison/blob/master/wifibot.py
Feel free to edit, share or reuse without mentioning credits :)
  • 1 × Intel edison
  • 1 × Seeed I2C motor driver v3.0
  • 1 × DC Geared motor
  • 1 × Groove LCD
  • 1 × Mechanix Toy building kit for chassis
View all 6 components
