People that got (and love) there DaVinci maybe got annoyed from the very loud behaviour of the printer even when printing slow.
* Progress *
- led strip replaced by WS2812B strip
- Silentstepstick made quite
- marlin firmware ready (went away from repetier)
- simplify3d config ready
* Todo *
- Interface orig. display
- Add RPi into the printer with REAL uart and NO USB.
- 24V supply and hotend (need to exchange the beds fuse for that)
- good docu
Files
Repetier-Firmware-2017-10-18.zip
Fixed the Bug "Missing line number".
x-zip-compressed -
482.32 kB -
10/18/2017 at 19:03
Objects were compressed in Z height by factor 0,75. Updating to the dev version from Repetier solved that problem. Do not ask me why that happened. Under files id uploaded a newer version of the firmware. Do not forget to Reset your EEPROM.
8.04.2017 Removed the original printer board and supply Use BETTER cables for the steppers to prevent the common DaVinci X-Axis problem! Got a temp. 48V power supply, in future i will use an PSU that fits in the printer.
