A Mini Dremel Drill Press for circuit boards
123dx - 584.82 kB - 04/12/2017 at 05:38
Added the 123dx file for easy editing and custimization in 123D and saving into STL
View project log
Stuff Needed
Im going to use bearings and a 8Mx300mm spiral rod from this old clay extruder. Ill add the components list in a bit
Im cutting a M8x300mm rod into 3x100mm
almost at 100mm
View all 8 instructions
Roger
Electroniclovers123
dombeef
Robin Hartley
Yes, delete it Cancel
You are about to report the project "3D Printed Mini Drill Press", please tell us the reason.
