back.stlbackplate has a 'clip' which should hold the charge/protect board. This needs reworkingthe pegs were designed to push though the pcb and into the front parts, but it turns out they are too difficult to print, so back to the drawing board there Standard Tesselated Geometry - 2.99 MB - 05/18/2017 at 08:45 |
top_original.stlthis bit is spot on, just cradles the top of the screen nicelyStandard Tesselated Geometry - 787.39 kB - 05/18/2017 at 08:45 |
buttons2.stlthe 2 little buttons for the font plate, tied together for simplicity. nice and basicStandard Tesselated Geometry - 1.09 MB - 05/18/2017 at 08:45 |
bottom_original.stlThis covers the bottom half of the font of the device. needs slight rework on cable exit for the power, and the joystick hole is a touch small. might need adjustment on the screen edging, seems a touch offStandard Tesselated Geometry - 821.57 kB - 05/18/2017 at 08:45 |
buttons_original.stlthis a top for the 5 way navigation switch, needs a spot of rework on the mounting on the bottom, its a bit too snugStandard Tesselated Geometry - 591.39 kB - 05/18/2017 at 08:45 |
