New CAD design
A project log for prism laser scanner
bringing additive manufacturing to the next level
hexastormHexastorm 08/12/2021 at 18:570 Comments
As said in my video, there are a lot of low hanging fruits.
The following improvements are made;
  - box is much smaller
  - photodiode flipped to opposite side (reduced size of box)
  - springs removed to adjust height photodiode and position first cylinder lens
  - added slit, simply clips all beams which are not refracted by prism
I changed the laser but want to move to a different housing, which is more compact and square.
In the image you can see the new photodiode board.
I attached an image of the new laser module, I want to use. It is more compact and has a cube housing
Anyhow will be on holiday coming weeks, so you'll need to wait for completion :-).
