Build tools update...
01/13/2015 at 07:58 • 0 commentsNow you can build firmware with: IAR ARM 7.2 and upper, CooCox 2.x, Keil 5.x , GCC ( tested with 4.9.3 ARM toolchain )
p.s: firmware totally tested only with IAR, other build not fully tested, but must works OK
Just some updates
07/28/2014 at 06:08 • 0 commentsBitbucket repo was update, some major changes:
1. Fix negative value representation for *HB03 devices
2. Add Keil 5.01 project to allow Keil users easily build this project ( i do not test it all but all builds and working OK )
3. Add handler for USB IDLE request ( it will fix some problems with some host HID drivers )
Moonglow
